Inside Sunroof Door Keeps Opening
My 2 previous Acura TL's interior sunroof door clicked into place to keep them shut. My 07 E550 just slides with no locking mechanism.
I did a search and all I could find was related to the E500's actual sunroof and not the interior door.
There is definitely a good deal of friction in mine that keeps it in place. The internal sliding panel slides on little "feet" in a rail. You can inspect these feet by removing the panel. Roll the glass sunroof back all the way, and unsnap and remove the interior leading edge plastic from it. This extra space is needed to lever the sliding cover part out. You should also unclip and remove the rubber bellows on the left and right side of the rail. The interior cover panel can then be slid forward and out the exterior part of the sunroof.
I do not believe this sliding panel is controlled directly by a control module, nor is it diagnosable using the diagnostic tool.
