19" AMG Style wheels starting at $649/set from PowerWheels Pro
Former Vendor of MBWorld
We just got in the new arrivals our 823s.
823:
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/P3103061_zps4376808e.jpg)
WHEEL SPECIFICATIONS
Size: 823 Style: 19x8.5/9.5
Offset: 823: 35mm Front 35mm Rear
Weight: ~26lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Gun Machined Face
Shipping: $85
Price: $649 non Staggered, $699 Staggered
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience.
If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
PURCHASING
You are welcome to purchase the wheels from our website at www.powerwheelspro.com or you can call your order in at 248 686 2035 or we can send you a paypal invoice.
Thanks for looking!
823s:
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/P3103064_zpse90856e9.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/P3103063_zpsd4d96a13.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/P3103062_zpse2195621.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/d4b58bc6-b5f9-4f26-8ac9-f6e44551ab8f_zps3b73602a.jpg)
Customer's car on these wheels 19x8.5 all around:
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/IMG_20130504_134634_369_zpscea60d92.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/IMG_20130504_134539_820_zpsa5421712.jpg)
823s in 18x8.5/9.5 on a W211 E55 (Also available $599/set)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/070_zps55d7a843.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/071_zps89a89950.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/072_zps2c768487.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/068_zps2cd6cbc4.jpg)
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/141_zps55933f23.jpg)
823:
Weight: ~26lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Shipping: $85
WARRANTY
PURCHASING
Thanks for looking!
823s:
![](http://i735.photobucket.com/albums/ww357/vpapadop/Mercedes%20wheels/150_zpscfcad995.jpg)
When are you getting style 811 back in stock? I emailed you in March and was informed you would be getting a fresh stock at the end of April and I would be emailed?
I have not received an email nor do I see them listed on your website.
Unfortunately we don't have them in those specs.
We do have the style 830 in stock in 18x8/9 35mm that will work on your E550 without any issues.
Thank you
Thank you
