V60 phone activation?
E500
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I just picked up an used E500 with the phone kit built in and the V60c. I noticed my V60i will charge, but it turns it off when I insert it into the cradle and the car doesnt recognize the phone. So Im guessing I have to use the older V60c that came with the car. I also noticed that the V60c is one where the antenna pulls out, does this mean I have to activate it through Verizon? Or I have to go through the dealer? Im a current Verizon user, can I just change the ESN numbers and start using the phone? Any help is appreciated. Thanks!
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The reason youe v60i shuts down is becuase it is not the 'Mercedes' branded Motorola. The Mercedes units have a different firmware than the non mercedes units.
This was done to keep people thatwant the integration to buy the Mercedes branded Motorolas.
If you have a v60c, then that is indeed a CDMA unit. You can activate it at any CDMA cellular provider in your area.
