E-Class (W211) 2003-2009
E320 Climate control
Old Aug 31, 2003 | 05:33 PM
konigstiger's Avatar
'71 Pinto
What is the function of the blue colored thumwheel in the center of the dash between the center air vents (#7)? The manual states that this thumwheel is for adding cold air. Nothing else is listed. Frankly, I don't see a difference.
Old Aug 31, 2003 | 05:46 PM
mike82y's Avatar
Re: E320 Climate control
The thumwheel is to control the air from (4), and only cold air comes out from that air vent. Sometimes in the winter you can close that air vent at the starting so the car warms up faster.
Mike
Old Aug 31, 2003 | 05:50 PM
jim256's Avatar
'03 Mercedes E320
When you are in "manual mode"--meaning one of the override buttons with the circular patterns on the switches, which select airflow from specific outlets--the blue wheel lets "untempered" outside air through the center outlet. Primarily, it's for cold outside air at the face in winter when heat is in use. It controls the opening of a valve electrically, so it's not an instant reaction when you open it. I could detect its effect last winter. In the summer, I presume it would just let in humid outside air when in manual mode.
Old Aug 31, 2003 | 08:50 PM
'71 Pinto
Thanks. How should it react in the "auto" AC mode? There's no difference in air flow to (4) or other vents.
Old Aug 31, 2003 | 11:54 PM
ICY's Avatar
ICY
In Winter, it's useful as you can control how much cold air comes in the central vents, which means you can have reasonably cold air blowing at your face whilst the rest of you and the car is kept warm depending on the temp on the climate control.
On long drives, it prevents the air from getting too stuffy and I guess the cooler air blowing on your face helps to keep you awake whilst keeping your feet toasty warm
Old Sep 1, 2003 | 09:09 AM
jim256's Avatar
'03 Mercedes E320
konigstiger: The book says the blue wheel only works in manual modes, and my experience confirms that. No effect in Auto. Since the actuator is electronic, it may simply not be energized in Auto.
Old Sep 1, 2003 | 11:27 AM
'71 Pinto
Thumbs up
Once again, thanks for the assist.
