Question in Regards to M113 and M155
... and if this is off topic for this forum to some of you folks, apologies in advanced but I never saw this question on the forum anywhere so lets crack the topic.
Just my thoughts, I could be missing something important but I believe that's what it means. It works off of the same fundamental block layout and design but with different internals, forced induction, headers, cams, compression ratio etc. I know you are probably well versed in how this all works but it helps me to lay it out too in writing to fathom what the difference is, don't mean to insult your likely more adept knowledge on these engines and forced induction
EDIT: I believe the M113 compression ratio is at 10.5:1 from factory, and 8.8:1 is much friendlier for supercharging as with any forced induction you lean up the fuel to air mixture quite a bit as well, another point to consider.
To answer your question Kleemann is a very good option (yet extremely expensive in most cases) for modding your M113 engine, if you have the cash they will most definitely be smiling every time you put your foot down. I actually asked about this in my recent thread and Kompression gave me good feedback:
https://mbworld.org/forums/e-class-w...fications.html
To summarize, you can probably save more money and gain more horsepower by buying a newer W211 quite easily (E55, E550, E63). I choose not to for a few reasons: I love my E550 and I am attached, I am lucky to own a German car with great mechanical health, and it isn't unique or special just to go ahead and upgrade to a model that thousands upon thousands of other owners drive. A Kleemann Supercharger staged build is something special and unique that may cost more money you won't get back in the long run, but will be a worthwhile mod in countless respects. If you go with a Supercharger and have more money after that (look at getting used parts too) you won't be able to screw out the possible horsepower without proper supporting mods. So consider your options carefully but I have a feeling it might be worth a shot
.EDIT: Also, in considering reliability tuning companies of high-end cars like Renntech, Kleemann, Brabus, etc rarely sacrifice reliability when it comes to modifying your car, and tuning nuances (little things wrong with the car after the mod that make it less comfortable as a daily driver) are few and far between so in that respect it is definitely not dumb. They stand behind their products too.
