E-Class (W211) 2003-2009
Old Jun 15, 2015, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
03 w211 Headlight Bulb Replacement
Old Jul 4, 2013 | 11:15 AM
mubs's Avatar
03 E220 Cdi
Hi,
my car is fitted with d2s Xenon bulb but it is very yellow want to have white one. can i directly replace it with HID d2s 8k or do i need blast i mean HID conversion kit for this? and also any advice how i can take my mian headligh bulb out as i did move to anti clock wise but it did not came out?
thanks
mubbs
Old Jul 23, 2013 | 09:26 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
you will need to get the whole HID conversion kit. Its really easy to do it. 15min DIY.
to remove the original bulb, just twist and pull. and you have to cut a small hole on the rubber cover to make way for the wire of the ballast.
Old Jul 23, 2013 | 10:55 PM
jwong77's Avatar
Why would he have to get an HID Conversion kit if he already has HID?
Hey OP, you should be able to find a replacement D2S Bulb and replace it. Not sure if anybody makes an 8000k bulb since that will be so dark it'll be next to useless. However, a 6000k bulb would really nice. Check out the OSRAM Xenarc, it puts out a nice white color with a hint of blue.
FYI, the stock is 4300k, so the 6000k should be much whiter.
Heres a discussion about it, http://www.hidplanet.com/forums/show...l-Blue-Intense
Old Jul 23, 2013 | 11:24 PM
beejAMG's Avatar
my bad. I didnt realize that. But I certainly dont think 8000k is next to useless. looks better imo.
Old Jul 23, 2013 | 11:25 PM
mubs's Avatar
03 E220 Cdi
Hi beejaypunsalan,
thanks for your reply. some one said to me that i have Xenon lights but when i opent the headlights they were no xenon so i have install HID kit with xenon lights 6000. which are alot brighter and white. one thing i would like to ask my xenon bulb are very cheap as they come included in £40 HID kit so one u said OSRAM Xenarc, if in near futuer i want to replase with these OSRAM Xenarc bulb can i do this or do i need a different HID kit.
mubs
Old Jul 24, 2013 | 12:28 AM
beejAMG's Avatar
if you have a low cost HID set up atm, you may have the cheap ballasts and bulbs that comes with it. if and when you want to upgrade like you mentioned, you might wanna think about upgrading the whole she-bang with a more expensive set.
