Keyless driver door access problem HELP!!
I am having problem with only driver door, its not working for keyless Go rest all are.
Can any one tell me what could be the problem and how can i fix it?
Thanks.
Basically, the rubber gasket splits and water gets in, destroying the electronics. It's only a matter of time, and the design was never improved. You can't just fix part of it, it requires a replacement of the entire door handle unit.
Add it to the list of cheap implementations of poorly thought out electronics which will ensure I never purchase another MB again.
rather let it be the way it is ... sorry for my bad English :P
are there any sensors or fuse for this which might have burnt out or something
There are MANY other possibilities that could lead to keyless entry not working. What I have explained is the MOST LIKELY issue. If you want to rule out ALL OTHER issues first, you must go to a shop with the MB diagnostic tool where they will tell you exactly what is wrong. This is the risk of getting help on these boards - no one here can diagnose your car definitively, and may give you the incorrect solution.
i think i will go to a diagnostic center for the problem.
Thanks apl175 for your help and effort.
