The only way you can successfully "patch" the rear bellows is if your leaks are in reservoir tanks. Spray the soap solution generously on rear bellows and watch for bubbles. If you are leaking from the bellows themselves then you are out of luck really. To "patch" the tanks, you will have to unclamp the hoses, use the tig welder to weld the corroded aluminum, install new hoses and good quality clamps. I've done this on mine and I've been leak-free for over 2 years. If you are leaking in front, then you can't get away with this as the bellows/bags are built in to the shocks.
