Headrest Fore-Aft Adjustment Stuck
2007 E280 CDI Sport
Hi, I've just purchased a 2007 E280 CDI Sport - great - however, the drivers' seat headrest is stuck fully out (towards me). In fact, by comparison with the Pax side, it looks like the front portion of the headrest has been pulled out beyond the frame where I can get my fingers into the plastic mechanism inside the headrest. However, I cannot find anything to press or pull to enable the front section to retract or push back.
Any ideas on how I might retract the front part of my headrest other than brute force and risk of breakage?
The Pax side pulls fore and aft normally; indeed, it does not pull forward to the extent that the drivers' side has been pulled - drivers' side is a good 20mm further forward and away from its frame and stuck solid; hence why I can get my fingers into the mechanism.
Any help/advice gratefully received
Many Thanks
Wolfie Souter
2007 E280 CDI Sport
Westbury, Wiltshire
Many Thanks
Wolfie Souter
2007 E280 CDI Sport
Westbury, Wiltshire
2007 E280 CDI Sport
There doesn't look as if there is anything inside the head rest except plastic cantilever sections, ie, no motors or solenoids. I don't know what active head restraints are supposed to look like.
2007 E280 CDI Sport
Thank you very much for your time plus advice!
Regards
Wolfie Souter
