E-Class (W211) 2003-2009
2009 Bluetec Reset DTC Codes?
Old Sep 2, 2013 | 01:20 PM
rogerdckwrth1's Avatar
09 E320
Hi, Got a code for the #2 glow plug and replaced it. Little coil light went out but "check engine" light still on. My OBD erased the code but it came right back. Do I need a special tool to reset? Will it reset by itself after several trips? Thanks, Roger
Old Sep 3, 2013 | 06:13 PM
09 E320
Replaced with dealer NGK.
Old Sep 3, 2013 | 07:39 PM
09 E320
Merceded Compatible scanner
Can anyone recommend a scanner, other than Star, that can reset the codes on a 2009 E320?
Old Sep 4, 2013 | 07:55 AM
09 E320
Thanks, I will try that today!
Old Sep 7, 2013 | 06:18 AM
09 E320
Went to Oreilly Auto and their $300 scanner could not read the codes. I had already ordered the Autel MaxiScan MS509 ($44) from Amazon. After figuring out that my car only talks to a scanner when idling, I got my codes. Could not erase the codes with the engine running but the scanner was smart enough to tell me that, so, codes checked, car repaired, engine light off. Repair was simple, I pulled the offending glow plug, checked it's resistance and it's glow with a 12V input, cleaned it and the connector, and reinstalled. I actually swapped the #2 with the #4 to see if the fault would migrate indicating a bad glow plug but it did not.
