Front lower ball joint question?
.........LOL.........seriously, good info to know for when I stop by dealer this week. Thanks. I always hear people say u must get alignment after this type of job??
This is my 1st repair on me. MBUSA Ext Warranty ran out end of Feb.. Gonna keep tabs of costs & not let myself get beat up frequently & cumulatively. This vehicle in particular is superb, but I don't want to spend thousands keeping it on the road in perfect shape.
You've got a few 'ball' joints in there: lower ball joint, upper control arm ball joint, and the thrust arm ball joint.
I changed out both lowers and 1 upper over the weekend. Parts are cheap, labor is expensive. Expect ~50 for each lower ball joint in parts....4 hours of labor each side I suspect. Upper should be around 70-110 ea (depending on where you get the parts at)...2-3 hours labor each side. Although, if you have a mono upper control arm (usually only early 2003 models) you'll spend quite a bit more getting the newer model upper control arm. Thrust arms/ball joints should be 60-200 each (again depending on where you get the parts at)...around 2 hours labor.
Of course we all know that labor at MB will be more.
Also, according to the prices you state above, would you say that to replace them would set me back about $1k?
