2005 E320 Transmission problems
Question?
-Should this be something to worry about?
-Is it even possible for my car to gave glycol contamination being that its a 2005 (04/04 build date)
-Possible culprit?
But of course that means a dealer or and indy with knowledge and tools--
My guess----- an issue with a solenoid and or does the TCU have the most current version of software!!
There is no sensor port on the transmission unless you are suggesting that the transmission conductor plate connector is a port.
Sounds like you are definitionaly confused and if you relate that information to an indy he will not know what you mean and you will get pissed off because he did not solve your problem--don't try to baffle him with what you have read---just advise that you believe there is a shift problem(define the problem) and let him use his experience to define the problem and estimate what it will cost to fix the problem!!
The car went into neutral a handful of times upon a moderate to heavy acceleration before I added the 1.5 quarts of fluid. I pulled over put the car in park and then drive and it would be fine. when the transmission was low and gave me a P0730 code. Question is did I damage the transmission or is this a safety measue the these transmissions do
. After completing the flush I was having the transmission going into neutral on hard acceleration (say it happened about 5 times) then I added the 1.5 quarts like 5 days later and its fine now Do you think this did any damage running in low 1.5 quarts for about a week of driving to work?
