Help with parts - 04 E500 4matic Wagon
2004 E500 Wagon
I am switching out my front struts to Arnotts - Preventive only!!
My first shot did not go amazing, it got done but!!!
The upper control arm is shot along with the - sway bar link (I think that is what it is called) - attaches to sway bar and control arm.
I just need to find out what fits my 04 E500 4matic wagon, vin#:WDBUH83JX4X119294.:confus ed:
I am having trouble finding these parts - I can find the control arms for the base models but not much for the 4matics, I cant find the sway bar link(probably I am using the wrong name) at all.
Can someone give me an idea were to get these parts.
In advance - thank you
In case anyone wanted to start another discussion I am using Mobil 1 ATF 134 in my transmission.
Craig
Craig
Looks like the control arms are 211 330 75 07 (L) and 76 07 for the (R)
What you call front sway bars could be 211 320 47 89 (L) and 48 89 (R)
2004 E500 Wagon
Is there an upgraded upper control arm?
Thanks for the quick reply, the part number are what I need, I found OEM on ebay and Autohausaz and Ebay, OEMs less expensive on ebay.
Do you know if there is an upgraded upper control arm for these cars? I noticed in other threads that the upper control arm for the base model has a removable ball joint with three bolts. Do the 4matics have the same option?
Thank you,
Craig
Thank you,
Craig
I have no idea about what you read regarding "upgrading"
Parts get added, deleted and superceeded and just because a part gets superceeded that does not mean upgraded. You can do the symantic research yourself!!
The upper control arm for the VIN provided has a part number that has not changed. The part number is 211 330 55 07 (L) and 57 07 for the R--no removable ball joint!!
