E-Class (W211) 2003-2009
Melted Crayon Smell from Heater Vents
Old Dec 19, 2013 | 09:55 AM
Shotime's Avatar
C43
With the recent cold weather, I've been running my heater quite a bit and, for the last few weeks, there has been a fairly strong melted crayon smell eminating from the vents. I did search MBWorld and other sites thoroughly to find many reports of such a smell but have not found a conclusive source. The most common culprit reported seems to be some kind of adhesive under the interior carpet but I am most certain that is not the cause, due to the following conditions:
-Smell strongest with heat on high and driving around town (stop/start)
-Very little smell on the highway but comes on as soon as I exit highway and slow down
-(here's the interesting part) Smell goes away completely when on Defrost!
Due to the Defrost taking the smell away, I've tried the following:
- Run A/C compressor with heater on...smell still there but possibly not as strong...
- Run just top vents to emulate Defrost and possibly focus on dash/foot vents...smell still there
-Run vents on cool and the smell goes away (but I freeze)
Question is...what is so different about the Defrost as opposed to running the heater??
I thought about recirc so maybe the cabin air filter being the problem, but my understanding is that Defrost does not use recirc but rather pulls air from outside.
I'm going to replace the cabin air filter regardless, because it is overdue, but I have little hope that'll solve the problem.
There has to be a simple solution that you MBZ experts will undoubtedly direct me towards, causing me to hoist a celebratory pint in all of your honors!
Old Aug 7, 2015 | 10:42 AM
vinman101's Avatar
2007 E63 AMG, 2008 Acura TL Type S
Crayon smell from heater
Hi Shotime,
I have a 2007 E63 and have the same exact problem. Did you ever find out what is causing it?
Old Aug 7, 2015 | 03:50 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Evaporator leaking.... nasty cabin air filter...
