How do you check the exact oil level using the dyno mode on a W211?
Scroll thru to the menu that gives you digital MPH it's a submenu there. do this with the engive off on level ground. When you get to the oil sub it'll tell you to turn on the ignition without starting the car.
He seems to say that there is a submenu, reached by holding down some button. There have been other posts suggesting that there is a "diagnostic" mode. I have never seen a post confirming this.
_______
Ed
I vaguely remember something in tha manual that gets you into the service setup. I believe at the FSS menu you press the reset button for a prolong period which will bring this up.
You're correct about how to get into the Service Menu. I just took a look at it and didn't see any entries showing the exact oil level. The regular oil level check is supposed to tell you if you're down 1, 1.5 or 2 quarts of oil, so Mercedes may have removed the information Frank sees on C class cars from the Service Menu on E's.
Dave
2003 E500 Sport Pewter/Charcoal
