Transmission flush what is the best coolant to use
2003 E500 sport
I am thinking if doing a radiator flush and I wanna know what is the best coolant to use and how much to use my a 2006 Mercedes e500 with out formatic. Thanks
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
You may best be served by a good indy---my reason for suggesting that is--- transmissions do not have coolant-----the engine has coolant and the transmission has transmission fluid-----if you are confused don't play around with the transmission----use someone that knows what he is doing.
But if you insist, make real sure that what ever you use, make sure the fluid meets the MB specs(Shell). All mfgs put that on their containers----read the stickies for the spec for your car.
Wow you are dangerous----same situation----only use MB approved fluids and distilled water----don't be lazy----search the forum there are hundreds of posts on radiator flush!!!
