E-Class (W211) 2003-2009
Navi programming for instrument cluster
Old Feb 20, 2014 | 07:36 PM
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
Post Navi programming for instrument cluster
Hi, people
I installed factory Navi to my pre-wired 03 E500, now everything working perfect. But i want to program my instrument cluster too to show directions. My friend have Star to do it, but we have no idea how.
Could you please write down step by step instructions for it?
Thank you!
Old Feb 21, 2014 | 12:18 PM
Diesel Benz's Avatar
Originally Posted by Plutoe
Tell your girlfriend the process is the same as if he installed any new control module----he has to go to adaptions and follow the self guided steps-----you do have the disc---right!!
Which disc are you referring to?
Originally Posted by noud
Hi, people
Thank you!
From Information and communication, IC-Instrument cluster, Control unit adaptations, Variant coding, Special equipment, change the "Navigation system" to "Present"and save settings.
The sequence could be a bit different depending on the diagnosis SW release your friend has.
Old Feb 21, 2014 | 04:26 PM
noud's Avatar
Originally Posted by Diesel Benz
Which disc are you referring to? From Information and communication, IC-Instrument cluster, Control unit adaptations, Variant coding, Special equipment, change the "Navigation system" to "Present"and save settings. The sequence could be a bit different depending on the diagnosis SW release your friend has.
Thank you! I will try it today. By the way, do you know how to turn off teleaid malfunction message on Star?
