Newbie Questions
Also I was told I can get bluetooth for the center console but there isn't a cradle. Can I still some out get bluetooth if so how?
Thank you! Ps sorry for my English
Whoever you bought the car from probably took the BT peice out
Did you see it in there when you test drove?
The "dynamic" setting will work inflating the sides of the seatback as you turn left or right and then deflate when out of the turn to sort of "keep you on your seat"
The pulse is just a "massage" for your lower back. It works 5 minutes at the time when pressed.
Of course all that info and more is in your owners manual
The car is bluetooth ready, as suggested above someone took it from the car at some point. You can get them on ebay and craigslist for about $100~150. The hook up is in the center console on the rear vertical wall, looks like a small plastic triangle.
