E-Class (W211) 2003-2009
Driver side rear lower than rest of car
Old Mar 13, 2014 | 10:05 AM
hutchinshouse's Avatar
2007 E350 (PZEV) Sedan
I have a 2007 E350 with 127,000 miles (without airmatic option). I bought the car used about 4000 miles ago. Not sure if this is a new issue or if it’s been there all along. I noticed this morning the driver’s side rear is ½” lower than rest of car. Using tape measure, driver side rear from ground to fender is 26”. Other three corners are 26.5” So we’re looking at a ½” offset. I checked, all tires properly inflated, car still drives very smooth. What could be causing this ½” offset? Are there any adjustments I can make on shocks ETC to raise the car ½”?
Old Mar 15, 2014 | 03:07 PM
veepei's Avatar
2002 C240, 2003 E320, 1998 Audi A4 Avant, 1968 lincoln Continental
there are spacers above the top spring perch that are removable. Make sure you have the same on each side. I removed 2 on each side when I lowered my car. 2 spacers is about 1/2 inch. Not a fun job unless you know someone with the Mercedes spring compressor. I did mine without. Getting the springs out was a battle. I couldn't imagine putting factory springs back in without the compressor.
Old Mar 15, 2014 | 04:27 PM
Wow, ok, sounds like too much work for 1/2". Thx for the info!
