E-Class (W211) 2003-2009
mbonefan
Old Mar 22, 2014 | 03:42 PM
HectorG's Avatar
2006 E350 4Matic
mbonefan
Hello, everyone, I am frustraded, owned a 2006 e350 4matic, cranks but it does not start, changed crankshaft PS, auxiliary battery, checked fuel pump fuse and relay they are fine, I can not check fuel pressure on fuel pump since it can not run, trying to avoid bringinit to dealer $,need help , any ideas to fix it, thank you, mbforum fans.
Old Mar 22, 2014 | 08:33 PM
hayseed's Avatar
04 e55
Back to basics,, compression, spark, fuel,,, pull a plug look for signs of raw gas,, then check for spark,, pull codes off odbii ,,,
Old Mar 23, 2014 | 11:36 AM
HectorG's Avatar
2006 E350 4Matic
mbonefan
Thank you hayseed, no raw fuel sign when try to start car, can you check fuel pressure if car does not start?7
