W211 2006 4Matic Wagon 350 check engine codes p 2240 i p 2237
W211 2006 4Matic Wagon 350 and check engine codes p 2240 i p 2237, does anybody knows where these sensors are located and how much are they?
Thank you
(((((((((((((((((((((.They said need more time and money to figure it out what is the problem!!! I'm sick of them only money for nothing!!!
PS. IS the high voltage codes come from the alternator?
I went to local mercedes dealer second time to diagnose and they told me to replace the both upstream o2 sensors and the throttle body and the problem will be solve, but not. As i said i replace the throttle body and both O2 sensors. I clear the codes and after couple of starts CHECK ENGINE IS ON again. Big nightmare. I can not stand this check engine light anymore.
So there has to be some connection between the throttle body, and both sensor to failure. Beside that the throttle body indirectly controlling the charge (fuel + air) burned.
In that meaning TBody failure is related to oxygen sensors failure. Correct or not. ????
