E-Class (W211) 2003-2009
2009 E350 ABR -- ABS/ESP problem
Old May 9, 2014 | 02:21 PM
neven22's Avatar
Hey guys I bought 2009 e350 I luv the car but I have problem with abs and esp sometime when driving shows abs/esp light visit workshop..
Code 47D8-test wiring system status- HOLD function for Voltage
Code 5490- HOLD function - Test cable Selector lever Position to N10/1
I checked all relays and fuses all good
also I bought new brake switch ..no problem
checked continuity from transmission shifter to front SAM n10/1 ....
abs unit has power to it ,,,
any ideas?.... i have no clue what to check anymore ....
I have star diagnostic system also..
thank you in advance
Hold function is part of ABS unit ?
Old Sep 28, 2015 | 05:47 PM
wisi's Avatar
2008 W211 E350 4matic
Same Issue i have in my 2008
Hi There!
Did you manage to find out what the issue is ?? I have the same Issue and i did not found any solution for this problem.
Thank You!
Old Oct 1, 2015 | 05:42 PM
neven22's Avatar
yes I did , it was front SAM unit, N10/1...
Old Oct 1, 2015 | 05:51 PM
wisi's Avatar
Did you replace it ? or fixed it ?
Thank You!
Old Oct 5, 2015 | 01:22 PM
neven22's Avatar
I found used and replaced it .....no programing needed .....
