E-Class (W211) 2003-2009
Audio Problems - no sound on drivers side
Old Dec 5, 2003 | 12:27 PM
michael10128's Avatar
2014 E350 4Matic/2011 E350 4matic / 2003 E500 /2000 CLK 430
Angry Audio Problems - no sound on drivers side
MY Harmon Kardon w CD Changer (non Nav) has a strange problem I am curious as to other experiences
When i am listening to CD's (mps based -that i burned myself) at a fairly loud volume for more than 5 minutes, all of the sudden the entire Left (drivers side) chanel goes dead...so its just the passenger side that has sound/power..
If i turn the unit from CD to FM and shut it off for about two minutes, it resets and its fine.. This has happened twice now..again only when listening to CD's as i was this morning..
ANY THOUGHTS??
Old Dec 5, 2003 | 03:58 PM
rdtjr's Avatar
2003 E500
This also happened to me when my audio went crazy. Had not reappeared since they reloaded the software but my wife says the sound is now unbalanced when she sits in the passenger seat even though my settings were unchanged.
The other symptoms/problems of overpowering static and losing control of ALL functionality - including the ability to turn off - have reappeared intermittently. A new feature has now appeared. After changing disks, display counts out first few seconds of the first song (but no sound) and then resets and starts playing normally.
Old Dec 5, 2003 | 07:07 PM
it could be my homemade cd's .. it manages to reset itself...after a minute or two switched to FM mode..and shut down..
Ill bring it in for the first check up, which isnt for another 9000 miles
Old Dec 5, 2003 | 07:39 PM
etenn's Avatar
E-500
Try playing commercial CD's only for a while. If no problem with them I would suspect your copied CD's.
I play a lot of copied and compiled CD's and have not had any problem on either the replacement or the pre-nav.
_______
Ed
Old Dec 6, 2003 | 10:53 AM
jim256's Avatar
'03 Mercedes E320
The MBCA "Star" posted a technical note to dealers a few months back that all CD problems must be demonstrated on commercial CD's, not homemade ones. As Ed posted, try to duplicate it on commercial CD's before you make your service visit.
Old Dec 6, 2003 | 04:52 PM
as soon as it stops snowing here...i will test it out...
