E-Class (W211) 2003-2009
diesel crank doesn't start , start with ether easily but doesn't restart cold or hot
Old Jun 27, 2014 | 01:02 PM
goulou1's Avatar
E320 cdi
05 E320 CDI W211
I have the car for a while 2008, I search in the forum but never found something close to my problem
leaving work (warm weather 22 C) I experienced a full cranking without any start.
Exhaust doesn't smell fuel
few attempts no joy
Tryed with ether (quick start)
** yes after glow plug where shut off and very lightly direct on the air filter**
-- started first attempt easily
drove to grocery store, performance was normal
tryied to restart after shopping no joy.
restarted with ether -- easily started
drove home try to restat a minute later no joy.
Code give engine crank sensor
but rpm shows on obdII
full fuel pressure at filter, when plug is removed (messy geyser :/ )
The only way to restart without ether is if the attempt is within less than 5 secondes.
Previously a had low turbo power intermittently.
I suspect the actuator .
mass airflow was cleanout (works ones than no effect)
turbo turn freely
actuator is easy to move
no leak in the piping
I dont thiink both problems are related.
key has brand new batteries now.
anyone encounters something close to it
thank you very much
Old Jul 2, 2014 | 11:10 AM
goulou1's Avatar
E320 cdi
Originally Posted by goulou1
05 E320 CDI W211
few attempts no joy
turbo turn freely
thank you very much
upd
crank sensor replaced
first attempt no start
second rough idling few second then shut by itself
no more start
Now we aiming toward the camshaft sensor.
when camshaft sensor is disconnected the code crank sensor disappear.
A note in the maintenance manual says no code might be shown for a camshaft sensor.
Someone experienced something like that?
Old Jul 2, 2014 | 07:50 PM
pinebaron's Avatar
07 E320 Bluetec
May have better luck in the Diesel Section
Old Jul 6, 2014 | 11:58 AM
goulou1's Avatar
E320 cdi
tks very much
I just did
i didn't figured out there was a special forum for diesel.
