E-Class (W211) 2003-2009
C/S button
Old Aug 3, 2014 | 07:40 PM
Merci2Mercedes's Avatar
E280 cdi Avantgarde 2007 & Ford Focus
C/S button
Can anyone tell me what the C/S button on my 2007 E Class does in more detail?
I usually have it set on S, but should I change this for motorway driving etc and does it have any affect on fuel consumption on either setting.
Thanks for reading.
Old Aug 3, 2014 | 08:13 PM
jimbo1763's Avatar
2007 E350 Sedan
Thanks for reading.
The C stands for Comfort. Essentially, the transmission skips first gear and shifts at less aggressive RPM's on the other gears.
The S stands for Sport. The transmission works through the entire range of gears and shifts at generally higher RPM's than when it is set at C.
Old Aug 3, 2014 | 08:47 PM
Thanks for the info/reply.
Old Aug 3, 2014 | 11:30 PM
Stuttgarten's Avatar
'13 E350 . M276
Also, when you're in the C comfort setting and you're backing up, it's a little bit of work for car, as transmission at this point starts in second gear.
Old Aug 4, 2014 | 10:59 PM
Thanks for info/reply.
Old Aug 8, 2014 | 04:15 PM
ttruex's Avatar
2004 E 500
Should there be any throttle drag while in C vs. S? Most automatics don't provide for engine braking to any great extent, but mine seems to act more like a standard than an automatic, even in C mode. Just curious, as it's my first Mercedes.
When you let up off the gas, it engine brakes, as opposed to coasting along.
Old Aug 15, 2014 | 06:56 PM
SorryAboutThat's Avatar
2018 C300 Coupe
This should only happen at low speeds, is normal and is supposed to help driving in "stop-and-go" traffic conditions. My understanding is that it's not engine braking. It's the hydraulic brake system automaticly being lightly applied.
Old Aug 15, 2014 | 08:24 PM
symon_say's Avatar
06 E280
Mine feels lighter in stop and go traffic in C mode, but C mode gives me worst MPG so i just leave it in S.
Old Aug 15, 2014 | 08:42 PM
AMGAffalterbach's Avatar
2014 BMW M235i
You press it and it redirects you to the search function on the forum
