E-Class (W211) 2003-2009
E320 W211 LED Parking Light Issue
Old Aug 10, 2014 | 11:42 AM
Vai2kdna77's Avatar
2003 E 320 Sedan
Hello Everyone! My first post here!
I upgraded the dim bulbs in the parking light position and the drivers side works fine, but the passenger side is bright for a moment, then goes dim. It even stays lit when the car is off. Any help? Also- My trunk close button no longer lights up and does not work. I am super new to the MB world and do not want to go poking around and making something worse.
Thank you so much!!
Kevin
Old Aug 10, 2014 | 12:40 PM
SorryAboutThat's Avatar
2018 C300 Coupe
You need to use canbus led bulbs. Just do a quick search on amazon.com for "canbus led" to find the bulbs you'll need.
Old Aug 10, 2014 | 02:24 PM
Vai2kdna77's Avatar
2003 E 320 Sedan
Yep, I did. One side works fine, the other doesn't. I swapped the bulbs from the socket and even the bulb connector and still the same passenger side low lit bulb. It stays on even when I turn the lights off. What can I check? Now my deck lid push button trunk won't close or even light up. I will check the fuses too.
Old Aug 11, 2014 | 08:48 AM
Vai2kdna77's Avatar
2003 E 320 Sedan
Ok- Follow up- So I could not locate the fuse for the deck lid closure button. I have looked around the internet for a possible solution. It literally worked the other day. Again- It does not light up, and is non responsive. How can I check this for the "cut wire" issue? Where can I look for recall items?
Sorry so many questions, I just love this car and don't want it going to crap because it is only 3 months old to me.
2003 W211 E320
Kevin
