E-Class (W211) 2003-2009
Location of Audio Gateway in Wagon
Old Aug 17, 2014 | 07:26 PM
cl600Mikey's Avatar
2005 E320 4M Wagon, 2013 E350 4M Sedan
Hello
Can someone let me know where the AGW and related fiber optic cables are located in a 2005 E320 wagon? I am installing a SDAR and need access to the fiber optic cables to put the SDAR in the MOST loop. I found pics showing the location of the AGW and cables in a sedan, but the wagon is a different animal.
Thanks,
Mike
Old Aug 18, 2014 | 11:24 AM
konigstiger's Avatar
'71 Pinto
Check your PM.
Old Aug 18, 2014 | 10:49 PM
cl600Mikey's Avatar
Thanks konigstiger for the info, I found that the AGW in my 2005 E320 wagon is located under the rear cargo floor, the front most panel pulls up once the cargo tie-down is un-bolted and removed which lets the panel come off. AGW and fiber cables are under that panel. Thanks!
Old Aug 19, 2014 | 01:54 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Pretty sure what you're referencing in that location is not the audio gateway, but in fact the telematics module. If you look for a W211 MOST loop schematic, you'll see that the sat patches in through the telematics module and through the nav drive and then into the audio gateway (which is attached near the rear driver side "quarter panel" area).
Old Aug 19, 2014 | 07:49 PM
cl600Mikey's Avatar
murman, thanks for the clarification. That may well be what I saw in the electronics compartment under the cargo floor panel was the telematics module, it did seem to have what appeared to be antenna wire connections. I didn't notice any fiber optic connections to that unit but I will have to look closer at it. That was the only module in the compartment, as the car doesn't have voice control or a telephone. I was just glad that I found the compartment, as it contains the necessary connection to the MOST loop!
I will post a pic or two when I start to install the unit.
