E-Class (W211) 2003-2009
Mercedes w211 auto gearbox fault
Old Aug 27, 2014 | 10:21 AM
shaz's Avatar
mercedes
Hello,
I have 2002 E Class with 722.6 gearbox I believe, The problem I'mm having is the car won't select any gear the fault codes I got from doing star diag are P2560/P2561/P220A, So i went and changed the conductor plate plug oil and filter after that car started working but then I notice it shift gears fine but wont down shift which I had to do with tiptronic which was working fine after couple of days the faults were back this time car has gone into limp mode and won't move at all when it does move only for few yards Star is only showing one code p2560 1st gear slipping or implausible.
All your help advice will be very much appreciated.
Thanks in advance
Shaz
