E-Class (W211) 2003-2009
s55 wheels!
Old Nov 25, 2014 | 12:37 PM
CDILoving's Avatar
2005 e320 cdi
s55 wheels!
Hi I just picked up some oem s55 wheels for my w211. I researched the forums and noticed I need different lug nuts, such as the: 56MM shank ball seat lug bolts for the front and rear. What else will be required?
Any help is appreciated.
Old Dec 1, 2014 | 10:01 AM
socalsounds's Avatar
2012 CLS63 AMG Performace - Obsidian Black
You'll see an offset difference as well.
Those rims will work, but both front and rear offsets are less for the W211 than the W220. W211= 30mm offset front, vs 44mm for the W220 = 14mm more sticking out more. W211 has a 39mm offset in the rear, vs 44mm for the W220, leading to 5mm more in the back. Rubbing could be an issue in the front, depending on what size tires you run.
