E-Class (W211) 2003-2009
DIY: W211 Rear Bumper Removal
Old Dec 10, 2014 | 11:01 PM
PutNavid's Avatar
06' E55 AMG, 03' E55 AMG
Hey everyone, I could never find a full diy to remove the rear bumper on the w211 so I went ahead and made one for anyone who needs it! Enjoy!
Step 1 Remove the trunk floor to reveal the tools and covered spare tire
Step 2 Remove the two screws in red and the pins in blue and remove the spare tire cover and the piece of foam covering the battery.
Step 3 Remove the four hooks held down with torx screws
Step 4 Remove the two pins on each side of the carpet siding.
Step 5 Remove the six square pins shown below
Step 6 Remove this piece of trim and dont forget to unplug the lights on both sides
Step 7 Move the carpet siding to the middle to give yourself some room. Remove these three bolts to free the air tank and move it aside. Do not unhook the air line just move it out of the way.
Step 8 Remove these four bolts. theres two on each side.
Step 9 Remove the three black nuts. You cant actually see them in the picture but I circled where they are.
Step 10 Now remove the nut in red and the pin in green. Repeat on the other side aswell.
Step 11 Now pull aside the splash guard and remove the bolt. Repeat on the other side.
Step 12 Remove the two bolts under the bumper holding it to the spare tire well
Step 13 Now just slide the bumper back and take it off and you're done!
Old Dec 10, 2014 | 11:33 PM
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
Great write up!! It looks an easy DIY. It should be the same procedures on AMGs as well. How long do you think you would take to do a rear bumper removal again since you already know where the bolts and pins located at....?
Old Dec 10, 2014 | 11:54 PM
PutNavid's Avatar
yup should be the same on the amg! If you have navi the dvd unit might be in the way of two of the bolts in step 8 but it should be easy to get around.
And well ive done this once before and that took me a while to figure everything out, this time it took me a little over and hour and a half to take the bumper off and put the new one on.
Old Dec 11, 2014 | 06:19 PM
JDM_SXE-10's Avatar
2003 E500
Very nice and detailed.
