Wear on cloth covering lower B-pillar...is there a fix?
It was idiotic of MB to use cloth on a wear surface, instead of plastic or something more durable, but, hey, German car manufacturers do stupid things like that (yeah, I own a BMW, too).
Anyway, is there a known fix other than replacing the worn cloth with a new piece which one can, presumably, buy from MB at a ridiculously high cost? (And that will, promptly start to wear out).
What that wear area really needs is a durable covering.
Anyone have a good/permanent fix?
- nocbs
I followed 65aircooled DIY for the most part. The 45 torx bit is required, and I also have a set of plastic trim removal tools, which aren't necessary, but help.
As noted I removed the seatbelt bolt, door weather stripping, and door sills.
I removed the old panel with all the clips attached - yellow and black. I then removed the clips from the old panel and re-installed the yellow clips on the car and the black clips on the new panel.
The seatbelt hight adjustment must be removed from the old panel and re-installed. Pulling one edge of the panel should allow enough room to release the peice from its track. I cleaned mine at this point.
Reinstalling the panel care should be taken to pull the seatbelt thru, and align the seabelt height adjuster correctly. There is a circular part that needs to seat in the adjuster, and the spring loaded lever needs to actuate correctly. Press the panel into the yellow clips on the car and press the top black clips on the panel into the car's slots. Replace the sill, weatherstripping and seatbelt bolt.
Good as new.
Thank you for the input, though. If I decide to sell the thing, I may just do as you say to make the car more saleable.
I do wish MB engineers used their brains a bit more before making these silly choices. I wonder if the crummy fabric survived the 2007 update on the W211. If it did, then they truly are brain dead and deaf as I'm sure they had plenty of *****es by then from owners of early W211s. $50,000+ and you damage the car every time you get in thanks to this nonsense. Sheesh!
- nopcbs
Good as new.
I have not had this problem, but that is what I would do if it came down to it.
