E-Class (W211) 2003-2009
SBC programming experience
Old Nov 17, 2019 | 04:02 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Originally Posted by Johnny L Ortega
I just order the recovery tool and should be getting it in a few days! I hate that message 😡😡
Old tale is cut a piece of black electrical tape over it. This way the annoying CEL will be invisible as well.
Old Jan 25, 2021 | 10:03 AM
Les P's Avatar
Mercedes W220
Hi. I know this is old but did you finally get this resolved?
Old Jan 25, 2021 | 10:49 AM
tripwalking's Avatar
04 E500 Wagon
I now have the tool but not the car, so if anyone needs it, make me an offer!
I'm in Ontario Canada but can ship worldwide.
dw
Old Jan 26, 2021 | 11:43 PM
ot1's Avatar
ot1
2006 E320 CDI
Owners living in the USA should know there is an extended 25 year warranty on the SBC system.
Old Mar 31, 2022 | 01:27 PM
Tom N's Avatar
w211 E350, 2006 model
SBC recovery tool. C249F
Hello, I need some help on the recovery tool for the w211. I got the dreaded SBC error this week. The narration on the diagnostic tool is clearly the service interval has been exceeded with corresponding C249F error. I have the same error message described in the thread.
I tried applying the recovery tool but nothing happened on the instrument cluster. This is despite the red pilot lamp being on and the tool's green pilot blinking for an extended period. I did my recovery when the engine was switched on after I saw same on a YouTube video where it was successful.
1. What am I doing wrong?
2. Does the recovery tool 'expire' after a single press even if the reset was not successful or it can be applied more than once with results?
3. Does it matter if engine is running vs just ignition in 'on'position?
Would really appreciate some help.
Old Apr 1, 2022 | 11:18 AM
Gangrene3075's Avatar
03' Mercedes-Benz E500
Sounds like you was sold a bad reset tool to me. If your in the U.S. your SBC should be under warranty. I got mines replaced at absolutely no charge.
Old Apr 1, 2022 | 11:40 AM
  #32
Wow...this thread bring back memories. I was trolled for using the SBC Tool. I remember my SBC was shooting two codes C249F and C2129.
I used the SBC Tool to reset C249F. Then I brought a brand new Pressure Reservoir and had a shop clear code C2129 with Star Diagnosis...
The SBC actually lasted about 4 more years afterwards. When the C249F came back that's when I used the warranty and had it replaced.
Worked in my favor it seems because I still have my W211
Old Apr 7, 2022 | 12:18 PM
  #33
Tom N's Avatar
This helps. I thought so too. I got the recovery tool off Amazon but I live in Nairobi, Kenya. I will raise a complaint and see what happens. Might you know if the same tool can be applied multiple times vs just single use? I appreciate the response.
Old Apr 7, 2022 | 12:27 PM
  #34
Tom N's Avatar
We get the short end of the stick with warranty issues in Africa generally. I approached my local Mercedes-Benz dealer in Nairobi about the SBC issue and why it appears different markets get different treatment as far as recalls go. They had to write to HQ in Germany to get direction which is pending. It something I feel strongly about and if it requires a class action suit to set a legal precedent on the issue in this part of the world, we will explore that.
