E-Class (W211) 2003-2009
Headlight Wiring Insulation Gone
Old Apr 10, 2015 | 02:47 PM
garrettmoore's Avatar
'09 E550
The insulation on all three of the wires that run to my drivers-side low beam headlight bulb has basically rotted away, leaving the wires exposed.
What's the best way to fix it? There is so little slack and room to work.
Old Apr 10, 2015 | 02:52 PM
Blitz2639's Avatar
2008 E350, 2010 GL550
Unfortunately a common characteristic. I just did mine recently and removed the headlamps to install HIDs and while doing that I used some felt tape and electrical tape to cover the exposed wires. Taking them out just makes it easier to work with.
Old Apr 10, 2015 | 10:43 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Consider a double layer of electrical tape with nylon Tye-wraps at each end to prevent the tape from unraveling. It is a PITA to wrap but it beats replacing a melted wiring harness. Remember, slower is faster. Take your time. A few extra minutes wrapping it now saves you hours on the side of the road later.
Otherwise, spend the money on a new harness and in a few years re-post the same problem.
Good luck with it.
