melted parts top og engine w211
i was checking my engine mounts,and when i tok off the engine panel,i found this,can it be leak at the injector??.cause i got some melted plastic smell in the car!
there is no moisture in the foot of the injectors, and there are no leaks.i hear no puff puff..hehe, and the injector that have done the damage to the foam looks new,so i think that the injector has been changed.will a picture of the injectors help?
Only thing which tells injector change for sure is if part number is different (substitute numbered part used). If used same part number you cannot tell... Also injector coding to ECU may reveal it (if not done properly coding is not changed - this is not always causing serious problems).
If car runs well and no problems with starting, no black death symptoms, just give her a hard drive
