Trunk Release Not Working
When I have the blade key in and turned, the trunk opens and closes normally either manually or with the door buttons. With the trunk lid open (and the blade key still in) you can hear the trunk release work when pulling on the trunk release switch on the door.
Electrically, everything seems to work. Until I remove the blade key and the release stops working again. It closes and the red trunk close button is lit up. I can't even open the trunk manually unless the key is inserted.
Any ideas? (2009 E550)
Finally figured out that I was turning the key too far back and activating the Valet lock. Turning the key back halfway and removing fixed the issue.
Relieved and embarrassed that I didn't figure it out quicker.
