E-Class (W211) 2003-2009
help with the Brake/ ABS off
Old Jun 2, 2015 | 04:20 PM
chase_tub's Avatar
E 350
Good afternoon folks,
Can someone help me to reset the Brake/ABS warning light & I was messing around w/ the "press the reset button 3 times feature, to see my battery level."
Old Jun 2, 2015 | 05:49 PM
samaritrey's Avatar
Super Moderator
THE C350
So were the lights on before or only after you went in to Dyno Mode?
If before you need to get the car on a star system to find out why.
If only after have you taken the key our and then put it back in? You may have put it in Dyno mode which causes all those lights. If you have done that and still have lights you need a star system!
Old Jun 2, 2015 | 06:15 PM
chase_tub's Avatar
E 350
Hi. Thanks for the reply. Yes the lights worked and so did the clock. Now I had to reset everything to factory. But I will try and go back and clear or complete all messages. Hopefully it works.
QUOTE=samaritrey;6452486]So were the lights on before or only after you went in to Dyno Mode?
If only after have you taken the key our and then put it back in? You may have put it in Dyno mode which causes all those lights. If you have done that and still have lights you need a star system![/QUOTE]
