E-Class (W211) 2003-2009
Leaking fluid
Old Jun 2, 2015 | 11:01 PM
07BlackWidow's Avatar
2007 E350
Leaking fluid
My wife noticed a puddle of fluid leaking right behind the passenger front tire and I think it's just water. It doesn't smell and dries up on your fingers quick. Any ideas of where it could be coming from? It running down the side skirt and coming out of the holes in that too.
Old Jun 3, 2015 | 05:17 AM
jimbo1763's Avatar
2007 E350 Sedan
That is most likely coming from the windshield washer fluid bottle-that is where is it located. To get access to it, you have to remove the front passenger tire and the wheel well cover. There are other links here with excellent instructions on that. The leak is ordinarily at the pump or at a particular grommet on the tank that goes bad. Has she been getting the "low washer fluid" warning?
Old Jun 3, 2015 | 09:52 AM
2007 E350
Ya the low washer fluid warning came on today, so I bet that's the problem.
Old Jun 3, 2015 | 10:25 AM
jimbo1763's Avatar
2007 E350 Sedan
There is a good PDF on this in post 12 of the following.
http://www.benzworld.org/forums/w211...reservoir.html
Old Jun 8, 2015 | 09:55 AM
stingray71's Avatar
2006 E350, 2006 C280 4Matic
This is a pretty common problem with these cars. I also had to replace the pump for the washer fluid reservoir. This is the black pump unit shown in the first picture of that thread.
Old Jun 9, 2015 | 11:13 AM
purplegrog's Avatar
2012 C250
If it is usually just a grommet that goes bad, can you just seal it up with silicone instead of replacing the pump/reservoir? Or is it more trouble to seal it up than it is to replace?
Old Jun 9, 2015 | 02:02 PM
stingray71's Avatar
The pump is only about $30, so if you are going to go through the trouble of accessing the washer reservoir, you might as well replace it.
Old Jun 9, 2015 | 09:19 PM
2007 E350
I'm going to try and look at it this weekend.
