ESP/ABS error + transmission limp mode
Coincidentally, had my brake pads/sensors changed recently.
Had the error codes diagnosed and got back the following:
6210: ABS antilock braking system control
4A42: fault in CAN communication with control unit CGW
54F0: CAN communication with control unit transmission control
C225C: Event: ABS control
Appreciate any suggestions on an "easy fix" vs taking it to dealer on flatbed and spending mucho $'s. Some posts suggest could be faulty brake switch? Sounds like some sort of electrical/controller error given all this stuff at the same time!
Thanks!
Thanks!
Is your transmission fluid level okay?
Sounds to me like a conductor plate/valve body issue.
However knowing exactly which faults set these lights off and which ones are current and stored would be helpful. STAR
https://mbworld.org/forums/m-class-w...nger-seat.html
I live in Houston and, like all rubber products, they turn to hockey-puck material. In particular the three drain plugs in the bottom of the well which now only work when you physically push on them. I'm not saying this is your problem but it's worth a look.
