E-Class (W211) 2003-2009
Technical Help Needed PLEASE!
Old Jun 21, 2015 | 12:42 AM
SortaBenz07's Avatar
07 E500
OK, I'm using a rear aluminum subframe from an 06 E500 in a custom application. I would like to run (ideally) a 3.27 gear ratio or somewhere thereabouts with 210mm axles. What year/make/model differential should I be looking for? It needs to fit the sub, and it must accept the 210mm axles. I don't care if it's open or LSD, but I need anything over 3.06 ratio. Any help would be appreciated! Please email me at Neil.gobbi@gmail.com if you can point me in the right direction. Thank you!
Old Jun 22, 2015 | 12:19 AM
samaritrey's Avatar
Super Moderator
THE C350
Curious what your working on but what you need to do is just search for every year and engine configuration. The info is out there on the interwebs but I haven't seen it all together or anything.
Old Jun 22, 2015 | 12:29 AM
07 E500
Just a little something I've taken on as a personal challenge, really. I've read countless threads about people TALKING about doing what I'm trying to do, but haven't found any threads where anyone actually attempted it. This is just the final piece of the puzzle before I start assembly. Not really wanting to talk much about it in a public forum, but shoot me an email and maybe I can fill you in a little bit. Oh, and I've searched and searched the Internet, but can't seem to get all of the info I need, such as whether the diff will mount in the sub I've got, or axle size, and in many cases the sellers don't know what the gear ratio is.
