E-Class (W211) 2003-2009
03 e500 door locks HELP!
Old Aug 5, 2015 | 07:36 AM
TooCalm's Avatar
2003 e500
I have a 2003 E500. Do not understand the key-go technology. Sometimes when I try to lock doors, front doors lock and rear doors stay open. I can lock all doors by pressing button on rear door handle (lights flash) and car is locked. When I press button on front door handle (nothing happens). Please explain the key-go process or do I need front rear door actuator??
TooCalm's Avatar
2003 e500
Old Aug 6, 2015 | 07:27 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
you mean keyless-entry/go right? i believe you can fix that on dash settings. just have to play around with it to find it.
Old Aug 7, 2015 | 10:09 AM
TooCalm's Avatar
2003 e500
Thanks beejAMG. I will try tonight. Does anyone have experience with replacing entire air suspension system with standard coil over shocks. I saw the complete set on Ebay for $1000 that came with a device that stops the light from coming on dash after you install. I have read a lot of messages about failed suspension on 03 E500. I have to look for the company.
