E-Class (W211) 2003-2009
W211 E500 Upper and Lower Control Arm Ball Joint Torque Specs?
Old Sep 18, 2015 | 11:31 AM
sidewayzgt's Avatar
2003 W211 E500
I have looked and cannot find the upper and lower control arm torque specs. I need them for the ball joints and connector bolts to the body. I appreciate any help.
Thanks!
Old Sep 18, 2015 | 01:41 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
wishbone to front axle carrier-110 Nm
lower ball joint-70Nm and 50 degrees
upper ball joint-20 Nm and 90 degrees
Old Sep 18, 2015 | 02:18 PM
sidewayzgt's Avatar
2003 W211 E500
Thank you so very much!
Old Dec 7, 2015 | 02:24 PM
Trevor D Porter's Avatar
2006 E350 Base, Sport, AMG Apperance Package, Panorama.
Great info! What about the forward control arm? I'm having a hard time finding the spec for it.
Old Dec 7, 2015 | 02:44 PM
cmriv's Avatar
Like your thrust arm? Not sure what you mean by forward arm-we all use diff terminology.
Old Dec 7, 2015 | 02:56 PM
Yes- Sorry, not sure of the correct name. I've heard it referred to as a forward thrust arm, so I believe we're talking the same part. Connect to the steering knuckle just behind the tie-rod end.
Old Dec 7, 2015 | 03:03 PM
cmriv's Avatar
The one that goes to the steering knuckle is 50nm and 60 degrees.
The bolt going through the bushing/to the axle carrier or subframe is 80nm and 120 degrees.
