E-Class (W211) 2003-2009
diy carrier bearing/mount replacement
Old Sep 30, 2015 | 06:46 PM
SH!FT's Avatar
03 E500
Just figured I'd share this info with others. Feel free to sticky.
http://www.pelicanparts.com/techarti...eplacement.htm
Old Sep 30, 2015 | 10:59 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Good info. I did mine on my e500 about three years ago. I did both flex joints at same time to save future labor time.
Old Oct 1, 2015 | 01:06 PM
SH!FT's Avatar
03 E500
Currently after I just repaired everything, I am experiencing squeaking when I go over a bump or a dip. Not sure if it is from the crappy ksport suspension that's on the car, or if it is a sway bar mount etc.
Old Oct 1, 2015 | 03:22 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
you could always remove your sway bar links then go drive it to rule the sway bar out of the picture.
Old Oct 1, 2015 | 04:01 PM
SH!FT's Avatar
03 E500
At this particular time, I'm looking or should I say focusing my attention on the wheel bearing adjustment.
Old Oct 1, 2015 | 04:50 PM
Common squeak when going over a bump or turning in parking lot is from lower ball joint. Trace it down with a mechanics stethoscope while someone turns wheel and while someone bounces the car.
