E-Class (W211) 2003-2009
HELP - 2007 W211 E63 - P0717 & P0731 Errors
Old Oct 2, 2015 | 02:14 PM
TTR's Avatar
TTR
R129 SL500 & W140 S500
Got these two error messages after the CEL came on. Since running the scan, the CEL has gone away. However, randomly and unexpectedly the transmission will refuse to shift gears no matter if I romp on it, put in Manual and try to shift. The only way to fix it is to stop and turn off the car and turn it back on. Anybody have the same issues or experiences?
Thanks.
Old Oct 2, 2015 | 02:20 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
valve body or conductor plate.... you need STAR to define exactly which one you need. These generic code readers are useless because you can't see actual values or do guided tests. Find someone with star and get it diagnosed correctly! step 1!!!!
