E-Class (W211) 2003-2009
2003 MB E320
Old Oct 11, 2015 | 02:17 AM
Diegobrings's Avatar
E320
2003 MB E320
I have a Q my E320 recently started to shake when I come to a stop I have no clue what it is and I would like to hear from you guys before I make any moves on my Benz
Old Oct 11, 2015 | 06:30 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
if it shakes less in N and more in D when in full stop, engine supports are shot. 2 at the front 1 at the rear. under $100 fix.
Old Oct 11, 2015 | 06:40 PM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
If it is shaking when coming to a stop, that is your rotors (warped) not your engine mounts. If it is shaking while stopped, that could be your engine mounts.
Old Oct 12, 2015 | 12:01 AM
E320
It's also rough when I go in reverse I have to step on the gas just a bit to go in reverse and when I do it shakes ?
Would this be engine mounts ?if so how many are they ?
Old Oct 12, 2015 | 01:27 AM
beejAMG's Avatar
Try to read post #3
Old Oct 12, 2015 | 08:23 AM
While your mounts maybe shot, sounds more like a rough idle. That could be EGR (very likely) or MAF. Clean both and see if it helps. If you clean the MAF and it is resolved, replace the MAF sensor. EGR can be taken apart and cleaned.
