E-Class (W211) 2003-2009
E320 auxiliary heater (webasto)
Old Oct 14, 2015 | 06:43 AM
esferato's Avatar
E320 CDI w211
Hello guys, my auxiliary heater is not working. Only works on diagnostic when starting test mode. Pictures is attached below with fault. Where i can found this thing? Any pictures of this valve location? Thank you
Old Oct 14, 2015 | 10:40 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Im not 100% sure but I think it refers valve which is changing heated water direction either to heat exchanger or engine block circuit... Its located near to webasto:
http://www.mese.fi/forum/userpix/3313_WP_000159_1.jpg
(in picture there is resistor installed to electric plug in order to ensure that engine block is heated all the time). Was there separate switchover valve test in star? It's not uncommon that webasto control unit itself is playing up.
Old Oct 15, 2015 | 03:58 AM
esferato's Avatar
E320 CDI w211
Didn't check yet. Will check on weekend
Old Oct 15, 2015 | 07:05 AM
esferato's Avatar
E320 CDI w211
Checked. Test show that something wrong and shows the same fault.
Old Oct 15, 2015 | 08:06 AM
mersum1es's Avatar
Did you check star finder that that's right part we are talking about... I have not heard this valve malfunctioning before, but it's first time for everything.
If you want try, put 15-16 ohm power resistor in valve connector plug, it should fake and emulate the actual valve...
Old Oct 15, 2015 | 09:01 AM
esferato's Avatar
E320 CDI w211
Only thing what I found by diag you can see on picture below. This time i didn't have star (borrow different diag). It is necessary to remove bumper or headlight to reach webasto?
Old Oct 15, 2015 | 09:46 AM
mersum1es's Avatar
You should see valve when you remove wheel arc liner, to reach webasto itself remove front most under tray. Control unit and/or connectors can be removed without dropping whole heater out, I just got my control unit repaired.
Old Oct 17, 2015 | 11:33 PM
esferato's Avatar
E320 CDI w211
Problem solved!!! Thank you!
Break in wiring. And that was the reason why this valve didn't work
Old Nov 24, 2020 | 09:23 AM
Sergejs Hlusovs's Avatar
w211
Hi! Can you tell, please, where the wire was damaged? Somewhere nevar the valve? I have the same problem, just have changed the valve and it does not solve the problem. I cant find damaged place.
