E-Class (W211) 2003-2009
Engine light on ( timing belt problem)
Old Oct 22, 2015 | 04:36 AM
Nicklin1's Avatar
E 280 Wagon 2096
Engine light on ( timing chain problem)
Hi- my mechanic diagnosed my engine light problem suggesting a stretched timing chain. the car runs fine no noises or any engine issues. Could this be a sensor problem or is the timing chain the real issue?
W211 E280 wagon
Old Oct 22, 2015 | 08:07 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Timing chain stretched-balance shaft gear worn-tensioner stuck-no way this is a sensor problem unless you have codes that aren't 1200 or 1208 current or stored in MOTOR ELECTRONICS...
good luck
Old Oct 22, 2015 | 04:08 PM
Nicklin1's Avatar
E 280 Wagon 2096
Thanks for the reply.
What is the easiest way to reset the computer so as to see if the light reappears?
Old Oct 23, 2015 | 01:31 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
OM642 stretch can be rather easily checked by anyone; open oil filler cap, you'll see tensioner shaft, if oil lubrication hole is visible, it's about time to change...
sorry flurry picture, took it from Finnish MB forum (courtesy of Aki P)
http://www.mese.fi/forum/userpix/470_IMG_0065_1.jpg
Old Oct 23, 2015 | 02:50 AM
Nicklin1's Avatar
E 280 Wagon 2096
Thanks.
It seems fine to me, the problem now is how do I get the engine light off?
Old Oct 23, 2015 | 02:59 AM
mersum1es's Avatar
Originally Posted by Nicklin1
Thanks.
If the original fault that caused the light is not longer valid, light shuts off after 3-5 successful (fault free) starts....
