E-Class (W211) 2003-2009
Measuring Engine Oil Level
Old Nov 16, 2015 | 12:44 AM
Stuttgarten's Avatar
'13 E350 . M276
I last changed my engine oil like 9K ago. Today, I decided to check level, and here is what I did, after car had been parked overnight.
Turned key to position 1
Scrolled to Temp
Hit reset button 3 times, which brought up Voltage and below was oil quarts, which looked like --,--.
I then turned key to position 2, and it gave me me an oil reading level of 6.5 quarts. Obviously that is 2 quarts lower than where it needs to be. I did my last oil change and I know I put in 8.5 quarts. Not sure why I'm getting this reading. Is there another way to read oil level? I miss the dip stick!
Old Nov 16, 2015 | 01:10 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
what you access was live data of engine oil volume in crankcase.
To check oil level, DON't hit the reset button.
Scroll the big buttons to pages with speed, range etc and playing with small buttons -after service remaining next will be oil level check. It takes few seconds to show if it is correct, or how much you should add.
Not extremely accurate per my experience, but has to do
Old Nov 16, 2015 | 07:41 AM
mtrevelino's Avatar
2006 E320 CDI
Please try the attached.
Mike T.
Old Nov 16, 2015 | 07:48 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Hmmm I hate that benz indicator... I just hate it!
Old Nov 19, 2015 | 09:29 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
Also, make sure your vehicle is parked on a level area or it will cause the reading to not read or an inaccurate reading of the oil level.
By the way, about 1 - 2 years ago my MB Dealer's Service Department overfilled my E500 that was not noticed until I drove the car at high speed such as 65 - 75 MPH. I received a dash warning notice that the oil was overfilled. I had to return it to the MB Dealer for them to remove some oil. Their mechs were getting lazy and didn't follow the specific specs for my vehicle: 8.5 quarts. I suspect they were putting in 9 quarts.
