E-Class (W211) 2003-2009
Suspension issue, need help
Old Dec 8, 2015 | 08:58 PM
alia95's Avatar
2005 Mercedes Benz E-500
Hey guys,
New to the forums, but read posts time to time. Anyways, have a little issue with me 05 E-500.
Recently a light came saying car to low, and basically the rear of the car is lower than the front of the car. One of my buddies said my front shocks and strut should be replaced. But it didn't make any sense to me because the rear is low. Because how would the rear be low if the front is need of replacement. Someone else told me it might be the air compressor pump.
Anyone have any idea what might be the cause of this. The rear suspension is low like to the ground low and I have attached photos. Any help with be great thanks in advance.
Old Dec 8, 2015 | 09:00 PM
alia95's Avatar
Attached a second photo
Old Dec 8, 2015 | 09:05 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Welcome to the forum.
Assuming you have full airmatic, the subject is pretty well covered on this forum.
If you have access to SD, it is straight forward troubleshooting.
Old Dec 8, 2015 | 09:12 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Best to get a Star Diagnostic scan and it will tell you exactly what is wrong and then you will not waste money on parts not needed.
Old Dec 8, 2015 | 10:27 PM
alia95's Avatar
Sorry I am new to MB world, any idea where I can get a good one of those? And are they complicated to use? I do a lot of work on my own cars, but i'm new to MB.
Also yes, its a full airmatic system. I am presuming its not a leak since both sides are low. Also I mean the front end is also low just not as low as the rear. I have tried searching the issue but have failed miserably to find anything. Any ideas would be great.
Old Dec 8, 2015 | 10:37 PM
I have my indie shop run the diagnostic with his Star system usually he does it for 40.00. The Star system as I understand it cost 1000.00 to 4000.00 including the software and computer. Other scanning systems will not give you all the info needed on a Mercedes. So getting a scan is much cheaper. I have a 2005 E500 with airmatic, an E63 with airmatic on rear and a GMC Denali with OEM air-ride. So I learned years ago that to try to guess whats wrong cost more.
Old Dec 8, 2015 | 11:00 PM
alia95's Avatar
Fully understand you now, if only I knew of any indie shops that use a star diagnostic system, any idea how I could find one, I'm in Boston btw.
Old Dec 8, 2015 | 11:21 PM
Here is a service center I found by google search Try making a few phone calls too. http://www.virtualeas.com/contact.html
Old Dec 9, 2015 | 12:20 AM
kajtek1's Avatar
One of the option before spending $100's on scanning is spending $50 on compressor rebuild.
Even if that is not your direct problem, compressors need rebuild every few years anyway.
Old Dec 9, 2015 | 12:38 AM
alia95's Avatar
Googled the rebuild didn't find it any help with a link?
Old Dec 9, 2015 | 12:39 AM
alia95's Avatar
Also emailed a few places to see if they have do star diagnostics. Thanks again guys
Old Dec 9, 2015 | 01:07 AM
kajtek1's Avatar
Not in stickies?
https://mbworld.org/forums/e-class-w...e-rebuild.html
