E-Class (W211) 2003-2009
2007 E550 4MATIC
Old Dec 14, 2015 | 10:17 AM
tmoE550's Avatar
2007 E550 4MATIC
2007 E550 4MATIC
So I just picked up a 2007 E550 4MATIC and I was already thinking that the V8 deserves a better soundtrack and probably brakes. When I do my research here, it seems like everyone does the mods I want to do but on non-4MATIC cars. My question is, what are my options for brakes, is there any way I can fit E55 AMG brakes on this car? And what are my options for the exhaust? Would I be able to get E63/C63 mufflers on this car or am I better off removing the mufflers and making my own pipes? Thank you for any insight.
Old Dec 14, 2015 | 12:42 PM
megasaurus's Avatar
2016 E63 AMG S SEDAN, 2010 E550 SEDAN
Benvenuto signore. Enjoy your ride. You can do all types of mods depends on what you really want to spend
Old Dec 14, 2015 | 01:52 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
yes-e55/63 calipers are a direct bolt on modification.
as for exhaust-search bar on the forum would be your best insight.
you will get alot of chimmers saying to do this or that but searching first could save you alot of hassle. It really depends on what kinda sound your goal is...
Good luck!
Old Dec 14, 2015 | 02:55 PM
tmoE550's Avatar
2007 E550 4MATIC
So I won't have to anything with wheel spacers or whatever to use E55 brakes? I guess I just want a sportier sound from it. I don't mind it being loud but I'd prefer to avoid having a bad drone. It doesn't appear that anyone really makes full exhausts for this car anymore.
Old Dec 14, 2015 | 05:31 PM
cmriv's Avatar
Wheel spacers will depend on what style rim and offset they are.... 5-spoke 2009 wheels fit fine. Not sure what wheels u have though...
Someone else would have to chime in on the exhaust note-that isn't my forte.
Old Dec 14, 2015 | 08:47 PM
tmoE550's Avatar
2007 E550 4MATIC
I have the 2007 sport package wheels.
Old Dec 14, 2015 | 09:16 PM
LemonSqueezy's Avatar
14 550 sedan
AMGAffalterbach with his muffler delete thread. Best bang for your buck.
https://mbworld.org/forums/e-class-w...althrough.html
I have a w204 C63 muffler on mine. Direct swap and sounds beautiful.
Old Dec 15, 2015 | 10:49 AM
cmriv's Avatar
You need to find out what offset they are and compare offsets to a set of 2009 w211 wheels....
Old Dec 15, 2015 | 10:50 AM
tmoE550's Avatar
2007 E550 4MATIC
If you don't mind me asking, how much did the mufflers cost you?
Thanks for that guide, I'm seriously considering doing exactly the same thing.
Old Dec 15, 2015 | 11:50 AM
tmoE550's Avatar
2007 E550 4MATIC
Hopefully they're similar, I don't want to have to mess with it too much in order to get them to work.
Old Dec 15, 2015 | 08:35 PM
t3404eo's Avatar
2007 E550 4Matic
I also have an E550 4Matic and I can't find any info on swapping the floating 2 piston front calipers for anything better like the E55 6 piston fixed calipers. Does anyone know where to find any info on doing a brake upgrade on a 4Matic 211?
Old Dec 15, 2015 | 09:39 PM
14 550 sedan
It was a couple year ago so I don't quite remember. I want to say about ~$650-700 from a forum member here.
As for the brake upgrade, maybe Kevin from r1concepts could help. He's a vendor here for brakes and pads etc
Old Dec 15, 2015 | 10:19 PM
t3404eo's Avatar
2007 E550 4Matic
No good at r1concepts for a brake upgrade. They only have a rear single piston caliper available.
Old Dec 17, 2015 | 02:29 PM
W211_350WagoN's Avatar
S211 E350 wagon, w211 e550 4matic, w210 2001 e320, 2023 glb250, 2013 Audi q7
Any updates on the brakes yet? Pretty sure rears will be no hassle but how about those fronts?
Btw I have c63 mufflers on my 350 and I love the sound!!! No drone so your 550 should give it a bit more throatier note!!
Old Dec 17, 2015 | 02:32 PM
One thing I've noticed is where the tie rod connects to the knuckle looks like the caliper bracket might touch ??
Old Dec 17, 2015 | 04:11 PM
cmriv's Avatar
211 E63 calipers are a direct fit....
Old Dec 17, 2015 | 04:16 PM
Should I change knuckle or have the bracket bolt holes machines bigger ?will this weaken bracket mounting points on knuckle?
Thanks...anyone have pic of them on a 4matic as I'd assume this be something one would kinda booste about considering the whole they don't work going around
Old Dec 18, 2015 | 08:44 AM
cmriv's Avatar
THE KNUCKLES ARE THE EXACT SAME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DIRECT FIT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:e ek::e ek:
Old Dec 18, 2015 | 11:03 AM
I'm not here to argue,but I know for sure the mounting holes for the brackets need to be enlarged to fit caliper bolts. Unless yours has sport brake in witch mine does not. That is why I said get new knuckles (from 4matic sport) my only concern is this... (I believe is my tie rod) also dust shields need trimming at that point by tie rod..
Old Dec 28, 2015 | 06:46 PM
Did you do it or know anyone who has to a 4matic? Figured I'd revive this since I've not heard back since....
Old Dec 28, 2015 | 07:32 PM
t3404eo's Avatar
2007 E550 4Matic
Unfortunately no. I'm not willing to buy the brakes for who knows how much to find that they don't fit. Please let us know if you find some examples!
Old Dec 28, 2015 | 07:38 PM
I'd be willing to put up half on the 2 fronts as I found a full set for 800 and can probably get the fronts for 400. That's 200 we'd have to put in each and the install could go either way if they fit. On yours or mine.
Old Dec 29, 2015 | 09:08 AM
cmriv's Avatar
yes-a co worker works on a w211 4matic that did the conversion. when i saw the vehicle i immediately asked him what needed to be done to convert-his response-r/r...remove and replace....
Old Dec 29, 2015 | 09:59 AM
Ok I know your getting a little agitated with the questions but do you see this car often and could snap a pic
Old Dec 29, 2015 | 10:17 AM
cmriv's Avatar
A tad bit however i have patience for those in need of help so here you go,
post #7 no spindle modification needed. I used the search bar in the forums to answer your question!
https://mbworld.org/forums/e-class-w...e-upgrade.html
