Panorama Sunroof
Called the dealer to see if there was a manual way to close the inside liner and was told no. Kept looking for a solution as it is still hot here in Texas with the sun coming through the glass.
Finally, I found in the owner's manual how to "reset" the sunroof after manually closing. I pulled the two fuses (41 in the passenger compartment box and 9 in the trunk box) and reseated them. Closed the fuse boxes, turned on the key AND...my sunroof closed inside and now works fine. So, in case you have this problem...try this quick remedy...it may work for you too.
Ive decided to just continue to enjoy the car and when something else major happens, get a replacement....I don't really mind a few hundred dollars here and there, but to spend $4K on a car that has a blue book rating of only $9K makes no sense.
Thanks for your input though.
I plan just to leave it closed permanently. Thanks for your input though.
Thanks for the suggestion...by the way, my dealer quoted $6500 for the complete replacement of the sunroof rails, pullys, motors, etc.
